My iPhone is displaying an error after I tried to launch an application that I had downloaded. This application was a game that I did not know about so I wanted to try it. I got it from iTunes. I have no idea how to solve it.
An unknown error message ‘APIEpicFail’, was received from the device.
My iPhone is displaying error when tried to launch application I downloaded
Hi Wallace,
This error seems to be occurring on a number of Apple devices. There are a number of actions that can be taken, including deleting the application and reinstalling it. If this does not work you can try respringing or restarting the device, and failing this reinstall the iOS your device uses. Another alternative is to create a new project and copy all existing content over.Â
According to the iOS troubleshooting updates, some solutions to restore your applications are provided. You should follow these steps if you get an error or alert message while you are using iTunes.
·        Remove existing and install the latest version of iTunes.
·        You should verify if your system is up to date. If not, update your phone software.
·        Check security software of your phone and update it if needed.
·        Switch off your iPhone and restart.
·        There are some unknown reasons when these error messages appear due to overloading or security       issues.
