How to repair when iPhone get soaked in water?
Hi everyone,
My iPhone got soaked in water and its wet. Can anyone give me some advice to save it from getting damaged?
Hi everyone,
Dear,
There is no specific repairing trick, but you may use the following things. Â May be your mobile will work fine.
Hope in this way you will be able to succeed in opening the mobile, although this is not a case where it would surely work but
90% chances are that it would work.
John
As wise people say that there is no remedy for all
Turn off the device (if it is not off) and completely covers the iPhone in a bowl full of rice. Rice is a natural desiccant and thus help to absorb excess moisture fully.
Now leaves dry out for about 48 hours and in any case do not charge the device. If your appliance has a removable battery, dry separately by covering it completely to accelerate the whole drying process. This home remedy is cheap and worth a try before rushing to the Apple Store for a replacement.
Hi Lilmonstha69
Check out this Techyv article. Here you will get 10 iPhone repair tips and tricks which you can do yourself to avoid wasting hundreds of dollars on a new device.Â
