Error 13010: My iPod cannot be synced
Asked By 820 points N/A Posted on -
Hi to all music lovers in Techyv, I have a problem with my ITunes application, my iPod won't sync with ITunes.   An error message will be displayed every time I try to sync.  Please refer below the screen shot I pasted.
The iPod “Jumal’s iPod” cannot be synced. An unknown error
occurred (13010).
What I did first, after I got the error message is, to restart my computer to get a fresh start.  When I tried to sync again my IPod with ITunes, same error occurred.  I even borrowed another cable to isolate the problem, but same error occurred.
I already ran out of ideas to isolate the problem.
 Please do some comment on my issue,
Best Answer by danica marie
Answered By 5 points N/A #122383
Hi there, deleting "iTunes Library Genius.itdb" solved the problem.
Answered By 0 points N/A #122384
This issue usually happens to the newly updated ITunes. There are a number of possible ways to fix this issue, these are:
  • You have to reinstall your ITunes. First, you have to completely uninstall/remove your ITunes from your computer, and then reinstall it afterwards.
  • Remove/uninstall back-up or anti-virus software. After you have uninstalled this software, try to sync you IPod with ITunes.
  • Sometimes, disabling, turning off or disconnecting of network connections (such as Ethernet Cables) will fix this problem.
  • Try to connect the USB cable for IPod to a different USB port.
  • Instead of updating your ITunes, try clicking "restore" and then re-sync your IPod.
Answered By 10 points N/A #122385
Hello James,
The following are the workarounds that you should give a shot and see if they will help.
  • First, you will need to try restarting the iPod.
  • If that does not resolve the issue, you will need to try restoring the iPod.
  • Still having issues? Then try unplugging the iPod and after that plug it back in.
  • Also try restarting iTunes.
Other workarounds you should give a try include the following:
  • Deleting the "iTunes Library Genius.itdb".
  • In case the above does not work, you can go ahead and try uninstalling iTunes, and then reinstall it and try resyncing after that.
Carl
