PC Keyboard Typing Incorrect Characters
I have a problem with my keyboard on my laptop.
Whenever I press the letter "A, C, W" the A comes with a S and the C with an X and a W with a Q.
I tried to clean up my keyboard, but it still has the same effect on it.
Is there something I can do to fix this?
Best Answer by burly
Answered By 0 points N/A #83328
Go to your Control Panel and check if the keyboard is properly configured depending on your country. Also, you may try the following troubleshooting below:
1. Clean your keyboard. There might be some dust behind those keys.
2. Install Intellitype Pro software. There are keys that needs this type of software.
– Intellitype Pro Software 32-Bit
– Intellitype Pro Software 64-Bit
3. Try to unplug your keyboard and then plug it back again and see if it works.
4. If the keyboard is plugged into a USB port or hub, remove it and plug directly to your computer.
5. Try your keyboard on another computer if the same issue will appear.
Answered By 0 points N/A #83329
Steps on how to fix your keyboard:
  1. Click start button.
  2. Click settings.
  3. Find control panel.
  4. Click Regional and Language options.
  5. Click the united states button both on upper and lower case.
Other solutions:
  • Try an external keyboard.
  • If this does not work try system restore to a point when it is still in good condition.
  • If this doesn't work, then its time for you to see a computer technician.
