Recently I had a KM Player setup and when I installed it in my laptop I didn't install well. i mean every time I open an audio or a video file and right click, then go to the "open with" option I find that KM Player is listed there, but funny enough I can't  trace It anywhere in my control panel list of programs.It doesn't even have a desktop icon what should I do because I want to maybe get rid of it?
candy
My KM Player did not install successfully
Dear Kioko,
Km player is a very smooth and fast running application for users to play media files easily with less hassle. It is very simple to use and needs specific plugins to be downloaded with it in order to get good performance.
Then run .exe file after download is finished and follow the steps in installation and accept recommended settings. Hope you will get the solution to your problem, thank you.
Jimmy001
KM player is the popular media player because of its remarkable interface and first running application. For good performance and easy playing options it attracts all.
First problem of installing km player is that the setup.exe file is corrupted or virus infected or any file missing. If it is occurred then remove the KM player folder. Download the updated KM Player from the internet. Install the setup.exe file again and restart pc. Play the KM player and enjoy it.
You can download codec for better performance.
Thanks..Â
