My KMPlayer has encountered a problem
Hi Experts,
My KMPlayer has encountered a problem. I think it was running well. Recently it shows the error message asunder. However, it is showing that the file format is not valid and it is applicable for all files.
Please help me to get a remedy of this problem.
The KMPlayer Invalid data type for ‘1s’
The KMPlayer
Answered By 0 points N/A #190926
Hello Nelson,
GOOD DAY!
I think you are in trouble with persisting troubleshooting. Here i am going to discuss about the complete prevention from this message.
You should download and then install the latest version of KM player and after resetting of settings and by setting the expected file with KM player wizard.
Download KM Player from trusted site
For eradication the problem stepwise then follows the instruction:
Download KM Player file repair tool
This kind of error occurs because kmplayer.exe file need to be situated in Windowssystem 32 folder as a default path but because of the misinterpretations of undetected spyware are happening this problem. For a fresh installing uninstalled the persists problematic installation file to get rid of the problem.
Reason associated with KM player error:
  • If the .exe file is corrupted or removed along with mistake.
  • If registry file is damaged
  • IF windows expired date is out
  • Because of improper file are installed or removed
  • Because of malicious spyware and virus invasion.
To fix the problem:
Start button> registry editor > type regedit in the search box > enter
Open HKEY_LOCAL_MACHINE folder > software folder> Microsoft folder> windows folder>current version folder
Select run folder> select km player.exe
Delete KMPLayer.exe .
Then reinstall it.
Answered By 590495 points N/A #315725
If you are using KMPlayer as alternative media player for Windows Media Player, try to uninstall and reinstall if you keep receiving an error. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select KMPlayer among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo Uninstaller then install KMPlayer back. You can also just download the latest KMPlayer if you haven’t updated yet.
If this doesn’t work, try using a different media player like this one I’m using: MPlayer for Windows. Try also using VLC media player.
