My laptop become slow so much
Your laptop configuration is good.Your Laptop is vista supported not Windows 7. Though your configurations are capable of running windows 7. But your will become slow if u use windows 7. You can use windows XP or windows vista 32-bit or 64-bit.If you do not have driver of your laptop you can download it from many sites. I am giving you a trusted site. Here is the site(link):
http://www.dell.com/support/home/us/en/19/products/?app=drivers
After downloading drivers you are ready to install your windows. After installing your windows give the drivers(if necessery) and install an anti-virus. There are many anti-viruses such as: Norton, Kaspersky,AVG etc. You can download Norton(from this site):
http://download.cnet.com/Norton-Security-Deluxe/3000-2239_4-10592477.html
You can use tune up utilities.Here is the link of the site:
http://download.cnet.com/TuneUp-Utilities-2014/3000-18512_4-10206416.html
By this your laptop will be fit and run smoothly.
If you have experience slow down of your PC performance, there might be something is happening in the background of your process. You may check some process in your process explorer. Possible unwanted process is running at the background that’s why your system runs too slow.
A large number of possibilities of the cause of slowing down the performance of a computer are the virus. Because virus creates its own process and use all your resources like memory and CPU speed. Some viruses, scanning your computer for possible files to be collected like important documents and images. Some are writing in your hard disk drives and much other attack by the virus which results to slow down your system.
Best thing to do with this is to reformat your computer and install a new clean operating system.
Hello there,
I'd recommend doing a couple of things. Run a good virus scan. I'd recommend using microsoft security essentials as it is free and very good.
I'd also recommend downloading a free trial of diskeeper's defragmenter. It's the best on the market and hard drive fragmentation is one of the leading causes of computer slowness.
