My laptop getting stuck when idle
I have Aspire One AO751h laptop with Windows 7 operating system in it.
It was getting stuck frequently so I thought it might be because of the DVD drive as it was making some noise. But, even after that it is still freezing all of sudden and I got to reboot the system. Just after reboot it is working fine for 2 to 3 hours of active use. If I am not using then it is not getting freeze.
Is this a problem with virus? Can I check anything from task manager to figure out what is causing the issue?
