Eaana Albert
2105 points
Posted on - 07/30/2016
Hi. I have a laptop which is working slowly these days. What are the possible steps which can be followed so as to learn how do I make my laptop run faster? Please reply ASAP. Thanks in advance.
My Laptop By Learning How Do I Make My Laptop Run Faster
Hi. The steps which need to be followed as to how do I make my laptop run faster are-
1) By uninstalling the programs which are unused and yet are occupying a lot of memory should be deleted permanently from the PC right away. This will improve the performance considerably.
2) All the temporary files comprising of everyday tasks and cookies as well as internet data should be regularly cleaned up so as to improve the power of the PC
3) A solid state drive which speeds up the start up process at least should be installed
4) If the hard drive becomes even 80% filled, then, it is time to replace the hard drive
5) You can run a defragment by clicking on start menu, then click on my computer. Right-click on hard drive and then click on properties
• Select the tools option and click on defragment now option
6) Clean the disk by clicking on start menu, then all programs, accessories, system tools and finally click on disk cleanup option
Hope we helped.
