My laptop pc is getting over heated
I have a laptop pc which is having trouble recently due to over heating problem. It was running well lately but nowadays it gets heated real quick and results in a automated shut down of the PC. When  I restart it shows the option to start windows normally. I do not know what is causing this problem. Please kindly help me get out of this problem. I need to work on my laptop consequently and without any disturbance so this is a real disturbing problem for me.
Leo Kingston
Best Answer by lorelei2011
Answered By 25 points N/A #115792
I have tips for you try cleaning your laptop exhaust space maybe there are too much dust in there you have to clean it by an air compressor, you have to blow the dust off the exhaust vent (make sure your laptop is already shutdown before doing this) try buying a laptop cooler it may help you. Check also if your laptop’s fan is still working it will help you also in cooling your laptop and  try to incline your laptop like this but you don’t have to buy something, you may use a Tupperware for air to circulate well on your laptop
Answered By 0 points N/A #115793
There are a few things you can try to solve this problem. First you should take all the access panels off the back of your laptop and blow them out with compressed air, make sure your fan is clean. Check that all your airflow vents are clear and not blocked by dust. After you have made sure that everything is clean put all your access panels back on and turn on the laptop. Make sure while you are using it that you are not accidently blocking any of your cooling vents which can happen if you sit with your laptop on your lap. Always try to keep the laptop on a flat solid surface to allow for maxium airflow buy a laptop table for your lap if you need to use it while sitting on a chair, couch, etc. Cooling vents and fans should be cleaned on a monthly basis to keep them functioning properly and to prevent overheating problems.
