My laptop screen is scratched
I have a scratch on my laptop screen.  There is nothing else wrong with my laptop.  I was wondering if there were any suggestions as to what I could do to make it better, if not repair it completely?  I hate that the scratch is near the middle and it is annoying when I work, it is right in my sight of vision.  I would appreciate any help.  Thanks.
Answered By 0 points N/A #191096
Disposing of scratches from any portable computer is simple with a couple of family things
Requirements:
* Toothpaste
* A delicate, build up free material
* A cotton ball
* Petroleum jam
Step 1: Place toothpaste on finger
Crush a little measure of toothpaste onto at the tip of your finger.
Utilization glue – not gel.
Step 2: Rub toothpaste on scratches
Rub the toothpaste over the scratch in a round movement for a couple of seconds.
Step 3: Wipe off range
Wipe the treated zone with a delicate material.
Step 4: Apply petroleum jam
Put petroleum jam into the scratched zone with a cotton ball.
Step 5: Wipe clean
Wipe the zone clean with a build up free material.
