My Laptop Suddenly Stopped Working
My laptop came across an issue few days backs it suddenly stopped working and there was one continuous sound coming from my laptop and it was not making any response its mouse pad and the keyboard was also not working o the other hand it was also not charging?
Answered By 0 points N/A #324197
I resolved my issue by doing following things firstly I tried to reboot my window as I thought it was a window issue than after changing my window I found out that it was making the same problem again there was no change than after than I tried to contact the company technical support team they noted my issue than after that one person from their team came to check my laptop than they found out that it was not a window or software issue but it was a hardware issue they changed my mouse pad and keyboard it correctly fixed my laptop and then after that my laptop was working fine.
Answered By 590495 points N/A #327103
If you have a laptop and it is now throwing one continuous beep on startup, try removing the memory modules since it is the only component you can remove easily aside from the battery. Turn your laptop upside down then remove the screws at the bottom from the memory modules compartment. You can find it a little closer to the center.
Before doing this, make sure the laptop is turned off. Once the cover of the memory compartments is removed, remove the memory modules from the slot. After this, turn on the laptop for several seconds. This should also create series of beeps so just ignore. After this, turn it off again then insert the memory modules back to the slot and close the cover of the memory compartment.
Turn the laptop on again then see if it still beeps continuously. If this doesn’t work, you need to bring it to a computer shop to have it checked what causes the beep.
