My Lenovo G55 Netbook monitor problem.
I have Lenovo G55 Netbook pro. While starting up it shows black. The monitor shows nothing but black. What is the problem with my Netbook monitor? What should I do with my Netbook? Please help.
Dear James L Evans,
The raised problem seems to possibly with the hardware itself. If it is under the warranty/gurranty period immediately go to a Lenovo service center. If it is not go to a nearby trusted service center who can check & confirm you about the actual problem. You haven't mentioned the location you live, so I can't help you with the service center address.
Thanks & Regards,
DBD
Hello James L Evans,
I Have Understand Your Problem About Laptop Showing Black Screen while starting up. There may be two Problems with your laptop
1Â with Battery
2. or with motherboard.
I am providing you the Solution For both.Â
If anything is wrong with Battery then
1. First Unplug the Charger from the Laptop and make sure Laptop is switched off.
2. Remove the Battery from the Laptop
3. Plug the charger with laptop and switch on the laptop
4. It will start. If this Works then You should have your battery replaced.
If the Battery Part does not Work then There is a problem with your Laptop Motherboard. You should Try repair or replace your motherboard. Motherboard is different for each laptop model. If you have any query let me know.
