My MAC computer is getting strange error
i borrowed my friend's computer for a day, then suddenly when I connected the computer, I got this message (ID=04).
what is this message about? Can it be fixed ?
Yes Sam, it can be fixed. Zero Divide Error for ID=04.
The Apple machine microprocessor was divided by two (2) numbers, in which the divisor is zero. This error happens when the user or a programmer put these in as debugging aids and forgets to  bring them back on its original state. There are chances that your friend did this procedure and forgot to remove it as debugging aids.
On the other hand, you may also ask your friend to remove it, so you can use his machine. If the machine was not set to its original state you will keep receiving the same error.
