Tareq
300 points
Posted on - 04/29/2011
Hello Everyone,
I'm using Apple MacBook 2GHz Intel Core to Duo. First of all, I installed Windows in my Mac and in the last few weeks I'm experiencing my laptop to be too slow, while it's being shutdown and turned on. I just don't know why this happened.
Is there any solution, then please tell me what to do.
Thanks,
Tareq
bappy
My Macbook performance is slow
Dear Tareq,
Your problem is very simple. First of all you're using Windows in your Mac and dual operating system always makes a computer slow. Now your solution is, you have to update your software properly. Software update properly means, you need your total operating system including all securities specially EFI updates.
Update is very simple. Just go to Apple menu and then click software Update after clicking Update software all software will appear in your laptop screen. Just install and restart your Mac. Your Laptop will be faster again.
Thanks
Bappy
Tareq
300 points
I've just update my OS, now it seems to be OK. Thanks for your information, but in my update I didn't find the EFI one.
Tareq
bappy
It's means your EFI and security are updated but you have to check it regularly. I think you should check your Update command whether you selected Automatically or Manually. If you selected Manually then turn it into Automatically. This will help you to update your all important software automatically. Thanks.
Bappy
Tareq
300 points
I've checked and it was Manually selected and I turned it to Automatically. Thanks, dude's a lot for helping me. Take care.
Tareq
sumya
Hello Tareq,
If you are using any pirated software, I'll suggest you to delete all of them because actually Mac doesn't support pirated software. I think you are also using the pirated software of Win XP. It would be better to use a licensed one. This might decrease your laptop's performance. Cheers!
Sumya
