My Media Player Classic has encountered a problem while opening a movie
Hi guys,
My Media Player Classic has encountered a problem while opening a movie.
The screenshot of the error message is as under. I installed DirectX 9 redist but no remedy.
Have you any idea for the issue?
Please help me to solve the problem.
Thanks in advance.
Warning creating EVR Custom render
No D3Dx9 dll found. To enable stats, shaders and complex resizers, please make sure to install the latest Directx End-User Runtime.
Best Answer by RANDOLPH Rosa
Answered By 0 points N/A #193223
Hi
I can surely help you to solve this problem. This is problem caused by Microsoft DirectX software. To overcome this problem just download and install DirectX software from Microsoft DirectX website. It will reinstall the required files to help play your video. If not then restart your pc then it will play fine.
Answered By 10 points N/A #193224
Either you video card is not compatible with the movie you are going to play or you require special plug-in to run the movie. You can check the format of the movie file and then see that your player supports the file you are trying to play and you will be able to solve your problem.
Smith Thompson
Answered By 0 points N/A #193225
Hi Hall Allen,
Does this error message always pop-up whenever you played any kind of movies or just a specific movie? If the first one is the case you must check and update your video card driver. Or if the other one is the case the movie that you’re playing is not compatible with your media player classic.
Update your DirectX from Microsoft download center, you can reinstall your DirectX from there or try to use another media player instead.
Answered By 10 points N/A #193227
This problem is created for the movie because i think the video format is not appropriate for the media player. If you want to watch that movie then you can change the format. I am sure that after changing the format you can play the video. So convert the video and enjoy the movie.
I am thankful to help you and please let me know when the task will be done.
Answered By 0 points N/A #193228
Hello Hall
Besides these procedures have many easy way to resolve this issue. Go this Techyv post to get more new easy techniques to solve this problem.
No D3DX9 dll installation error message
