When using my microphone on any means, it emits a intolerable noise. I tried various microphones, changed my PC but the noise was still there. My old motherboard has Realtek and there is an option to control the noise. But when I changed my motherboard to ASUS with VIA VT1705 HD, there is no option for this. Are there any other way or program that I can use to control the noise on my microphone?
My microphone is sending lots of noise.
You can eliminate noise in the audio either by installing new software or adding a new hardware with your PC. There are so many noise suppressing hardware device in the market which you can buy to connect with the motherboard. Before purchasing the board verify the power requirement. Power requirement of some of the noise suppressing device is very large which your PC cannot provide. Those are designed for other application like car. You need to purchase one which is designed for PC and which can operates in the power of your PC motherboard.
There are also so many softwares which you can install in your PC to reduce noise or to shape the voice. Voiceshaper is one of the great software for this. Also you can try SoilCall pro software. But always by attaching a noise suppressing device with your hardware you will get better performance.
