My mobile cannot connect with mobile internet
My Google IDEOS mobile works only with wireless network but not in the mobile network, What shall I do?
I think I couldn't set VNP properly,
Please help me.
Please help me.
Hello there,
Well Google Ideos is built for wireless Internet. If you want to surf internet then well you just need to change the mobile settings and if it still doesn't work than you need to contact your service provider.
The best thing you can do is data tethering by just going to Settings and then Wireless ad networks and then hotspot and tethering and Turn ON Tethering and that's it, you can now share your mobile internet on your laptop or Computer.
Hope this helps,
Cheers
You Google Ideos has HSPDA 7.2 Mbps on it, so it should work via Mobile internet. However, you have to make sure though that your network provider does not require Plan enrollment or number activation in order to use mobile internet.
You can call your network provider so they will give you a walk through how to activate your phone or number for mobile internet.
