My mobile charger is becoming hot in charging
It often happened with some mobile chargers. It has happened because of the circuit (situated in the charger) board has some damages. You have to see that your electricity line is perfect or not.
You have to confirm that there is no up-down in the electricity line. It sometimes happens because of your electricity. If your line is ok, it might in the charger. You can repair or replace your charger. You might change your circuit board.
Change the circuit board and your charger will be new as it at first. You can replace it as it is so cheap rated. Think you have got your answer.
This normally happens to "Fast chargers". Fast chargers are chargers that are capable of supplying a large amount of current to the device that it is charging. Most mobile phones (as well as other battery-powered gadgets) nowadays use Litium-ion battery packs.
Lithium-ion batteries have a circuit that regulates the flow of current during charging depending on how much charge it currently has. The lower the charge a Li-Ion battery pack has, the more current it draws from your mobile charger. As the Li-ion battery's charge increases, the amount of current it draws from your mobile charger decreases.Â
When you try to charge your mobile phone when it is almost out of battery power, the battery will initially draw a lot of current from the charger causing it to get hot. Don't worry, that is normal.
As your mobile phone gradually gets charged, it will draw less and less current from the charger until it reaches 100% charge and only draws very minimal current. You will then notice that the mobile charger will be cooler by then.
Hi Lily53,
The reason why your cell phone becomes hot when charging is that the watts of the wall socket you charge maybe not suitable to the charger you use or the charger you use is not suitable to the phone you use.
There are phones that can be charged by using other types of charger but without knowledge that it will cause short circuit and will destroy the battery of our phone
Thank you.
Mary
