My monitor was LG , It shows me some problem.
In my monitor it show me a boder like as line its color is white . I am a new user so i can not find what should i do now so please tell me what can i do now……………………………………
Hello Estive Serve,
I encounter the same situation when I first got my laptop given to me. It has border like line in my monitor. Gladly, I know exactly what the problem is which I will show it to you how.
See the instructions below, this will clear your mind from worrying.
This is cause by the settings of your monitor. Driver might needed for this to update the graphics of your monitor, VGA card and other hardware installed in your computer to enhanced graphical image. Your inquiry has no screenshots so I can’t really picture out what it look like. Yours might be different than what I encountered. In my case, I did upgrade/update my VGA card controller; I installed and inserted the driver provided by my computer manufacturer and it fixes my problem.
To update the driver CD/Disk
-Insert the disc/drivers and utility, ran the disk and follow the instructions.
-This usually fixes and might change the looks of your monitor. This will either enhance the graphical image and the text size.
This will remove the border line like images in your monitor. Check also the auto-adjust in your screen located in front of your monitor. These are buttons that can be press to adjust the brightness, color and the sizes.
Hope this helps.
