My mozilla firefox downloader is not getting speed
The downloader of Firefox is nice. The downloading speed is not rely on your downloader. It depends on your net speed. If your net speed is okay then you should close your connection and restart the connection. If it is not working try a new downloader software. downloader software will help you getting the speed that you needed.
There are many downloader. Such as: IDM (Internet Download Manager), Orbit Downloader, DAP(Downloader accelerator Plus) etc. By using this softwares you will get the speed. Or, you can upgrade your Mozilla. You can download these softwares from this site:
Please Check your Mozilla Firefox version is older then you will please download new version and check again.
Thanx & regards.
Solution.
Hi Lily
I read your problem. But I Think this is not very critical problem. Now I try to give some workable solution for your problem. Please read the below solution and work step by step then I think you will cover up the problem.
Yes there is alternative option for this kind of problem. But downloading speed not only depends on your software but also depends on your net speed and your browser. You can change change your net connection or you can change your browser if it was older than present or you can upgrade your download software.
Otherwise if the file size is so much than it takes too many time or if the computer was run so much program than it takes lot of time to do that. So I suggest that do one thing at a time not so many if is your problem otherwise you can change or upgrade your software or browser.
Hope your problem has been solved by these solution.
Thanks from
Arafat hossain
