Somebody interfered with my computer and specifically my Ms Word , and every time I open it only shows Grid lines. Even after uninstalling and installing it still brings the same thing when I try to open. What should i do or which settings should I change to make my word be reset to a blank document when I open?
ramodive
My Ms Word is showing Gridlines?
Drawing gridlines appear only in Print Layout view.
On the View tab, in the Show/Hide group, select the Gridlines check box.
You can change the spacing between gridlines and the starting point for gridlines. To temporarily override grid settings, press ALT as you drag or draw an object.
imranmic
Show or hide drawing gridlines
