Hi Experts,
My MSI Afterburner Remote Server has encountered a problem. It is showing an unknown error. I received the error message starting the server. The current operating system of my PC is Windows XP 64-bit and Android 2.3 with my phone.
However, they cover all the requirements of the application.
How can I get a remedy of this issue?
Please help.
An unknown error has occurred. Please see log for more details.
Hello Jhon,
That is an error possibly due to the ports that you are using. You will need to confirm if you maybe started getting the error when you switched to another port. You will need to changing to port 82 and then restart the server and see if that will resolve the issue.
Nicke
Hello John,
Unfortunately, that error message is a general message it sends to say that "something is broken".
That will mean you have to run a lot more diagnostics.
So here is what could be causing it.
1. Graphics Card Problems
2. RAM Problems
3. Power Supply Problems
4. CPU Problems
5. Flash
You can try common solutions like, reducing memory timing of RAM,
Replacing the RAM or can uninstall the program then re-install it. You can also use a link.
