I have connected Nepton 240m cooler to my gigabyte GA-X99-UD4 and whenever it starts, the pump generates a lot of noise. I counter checked fan speeds and found out that the pump is not functioning at all and the temperature on my 5820k rises to anywhere between 85-95 degrees. Whenever I restart it, it works fine for a while before it begins overheating once more. I have connected the pump to the opt fan header of the CPU and the set the board to run silent settings to control the opt. Is there something I have not configured well? Should I run this at constant settings?
My Nepton 240m pump fails to start
Hello Derrick!
This a good system enhancer and cooler. With regards to your problem you mentioned that you’re hearing sound coming from the cooler itself. Please make it sure that you attached this cooler properly in your tower. Locking all the screws tight and there’s no gap between the cooler and where it is attached. If the sound is really coming from the cooler itself please remove it and might cause you more trouble. Better to bring it to the retailer. There’s nothing wrong with the set-up you did. All default settings for our computer in general are configured and set to make other devices to work properly. Coolers were also configured with the minimum default settings of any computer regardless if it’s branded or generic.
