jason765
Posted on - 10/15/2011
I have Nokia N8 model the problem with my set is very critical. Because when i dial a number for call then the problem will start . And the problem is that during call my Nokia N8 will automatically restart. After restarting when I again dialed the number then call dialed. Now this is the major problem which i am facing now days and i am not able to call first time so please help me?
Allan O
My Nokia N8 auto restart when I dialled number for call?
The best thing to do under your circumstance is to get to the nearest Nokia dealer to get you problem fixed by either repair or getting a replacement for your Nokia N8. If you will press on to try fixing it personally then try this procedure we used on my friends phone and it worked. We downloaded the Navifirm from the web address:
Then we downloaded and got Phoenix 2010.8 installed, after this step going on successfully we opened Navifirm and waited for the products listed to get loaded.
We then looked for the searching variant then we marked all and then clicked on downloaded the program and saved the file to a location we knew. we then copied the file to program/files/Nokia/phoenix/products/r-596/ at this point we got the Nokia N8 connected and opened phoenix 2010.8 we went to file clicked on product scan and followed the steps concisely ignoring warning and waited patiently to let phoenix complete its processes. This steps if followed patiently can help you fix your problem.
if you are facing this problem in your nokia n8 i will tell you what to do because i have also used this mobile its very dangerous virus in your mobile because your phone is symbion phone so u must install your software in your mobile to avoid this problem and i suggest you to install new software as soon as possible !
