My old crt monitor automatically turns off when booting Windows 7.
Asked By 130 points N/A Posted on -
Please, help me.
My old CRT monitor automatically turns off, when booting windows 7. But when I'm using an older version of Windows, my monitor is working properly.
Is this a problem of incompatibility or something? help me guys.
Best Answer by pheetong
Answered By 0 points N/A #112474
I have encountered the same problem before. It's on the resolution. Your resolution is very high for your CRT monitor.  Just pick a lower resolution and the problem is solved. good luck!!
Answered By 0 points N/A #112476
I agree with you, Mr. Jhune. Some old monitors may not be compatible in high resolutions for Windows 7 in modern LCD monitor.
Just try to use a lower resolution, that will fit to your display.
Answered By 130 points N/A #112478
Thanks! but how can I change the resolution?  if I can't even boot Windows? It automatically shuts down, upon loading Windows.
Answered By 0 points N/A #112479
In your case, I guess the only solution is to first connect  your system unit to a different monitor that supports higher resolution. Then change the resolution of your Windows.
Now try it again with our old monitor.
Answered By 130 points N/A #112480
Thanks, may be I'll borrow my friends monitor first ^_^.
I hope this will solve my problems. Thanks any way.
Answered By 0 points N/A #112481
I'm pretty sure, this will solve your problem if there is no defect with your hardware. Good luck ^_^
