Linda Prey
230 points
Posted on - 07/02/2011
I use Nokia 5130 java phone. I have Opera Mini 4 as my built in browser. Recently I downloaded Opera Mini 4.3 in to my mobile. After few days of use it got corrupted.
Then I tried to uninstall it and it says it can uninstall Opera. I also tried to update it and it says same version exists and it can’t be updated. Now I can’t use my default browser and can’t browse the web.
Is there any solution for this problem?
My opera browser is not working anymore
You have got a peculiar problem but I hope there are few solutions for that. First take your mobile to some servicing center for giving Flash to the mobile phone. But if you have some important data then first backup it like mobile numbers, messages etc. Because all of your data will be deleted after you Flash your phone.
If you don’t want to Flash then there are other options like using other browser. There are other browsers like Opera named as UC browser, Bolt browser etc. You can download them from https://www.getjar.com/ and install it to your phone. And the last option will be RESET your phone to the factory settings so that it can restore all default option that was in them when the set was made. I think anyone of these solutions will fix your problem.
But if the problem persists take your phone to Nokia Customer Care and they will solve your problem.
Connect your phone to your PC and delete application data from there. After complete deletions install fresh Software. If does not work than try to install advance version of this software.
