My operating just got stuck Please help me out
Hello, I'm using windows 7
Please help me outÂ
Can anyone help me out this situation.
Please help me outÂ
You have just clicked a website that contains malware, made sure to remember the site and never visit it again you can try two ways to fix your windows but you need a genuine CD and a product key for this. Make sure to boot first your optical drive in the bios setup.
Solution 1: Reinistall Operating System
Solution 2: Install a fresh copy of Operating System
Note: Remember backup your important files using a bootable OS disk so that you will not lose important files.
Operating System stock. To get out of this situation, there are 2 ways to get out.
Check for possible hardware issue. All hardware components has to be installed properly.
Not loose, hardware has to be properly seated and can't be wiggle when holding the card. All these has to be check.
If a hardware encounters problem, then you'll encounter software issue.
Check for software driver. Re-install Windows if possible. Do the safe mode log-in and clear all possible browsing history, cached file and other cookies.
Once step is done and OS still stock then we have problem with software here.
So, you'll only options is to re-format windows.
Do this steps and it'll get you out of this situation.
