45peeter
Posted on - 02/27/2012
My operating system opens anything in dream Weaver software. I mean I am using notes 8.5. if I click on a link in notes it opens dream weaver. I have made internet explorer my default browser. It’s not working.
Please suggest me some solution.
Dear 45peeter
The problem is not with the Operating System, it's just some settings in Lotus Notes. In order to open the needed link into Lotus Notes 8.5 in your default browser Internet Explorer or any other browser you would like to use instead of opening it in DreamWeaver, In the "Preferences" of the Notes 8.5 go to "Location preferences" and set the value "default browser" to the value you would prefer to open links through it. Now whenever you try to open a link within notes, it'll not open in Dreamweaver, however your default browser will be used to open links.
Hope this may help you.
Best of luck
