My OS x Mountain Lion is draining my battery life
Hello
My MacBook Pro battery life has diminished since upgrading to OS X Mountain Lion. I have of course contacted support and gone through Apples Support communities but they have no solutions yet. Can anyone give me some advise
Thank You.
Best Answer by Fosso pradha
Answered By 0 points N/A #130213
It is hardware problem not a software problem. You can contact with Apple support center for solution. You said that you have already contacted with Apple support communities but you don’t find any solution.
Apple is concerned about this problem. I think they will immediately provide a solution for this problem. So wait until that otherwise you have to re-install your OS. Thanks.
Answered By 0 points N/A #130214
Dear User,
We have seen many users are troubled and complaining about this issue.
That the latest version of Mac OS has caused a massive deduction of the battery life.
But the good news is apple is continue sly and reportedly investigates about this issue.
And they will definitely fix this with their next update.
my advice is not to use this OS until you get a fix .
Thank you
