My PC get crashed on Real Player latest edition
My OS was windows 8, and I've install Real Player latest edition, the problem is every time I launch my real player with video of any length it freeze my computer and there was no information displayed on the page. Is real player latest edition compatible with windows 8?
Best Answer by Arcel Ramo
Answered By 0 points N/A #140787
Hello there Frank Rivera,
Your problem is very common about real player. Problem occurs when real player launches video it will freeze and shutdown. The explanation to this is that your video card that does not understand the instructions that real player is giving to it.
Here are some solutions base on my research.
Solution 1: Set your video display to 16-bit color.
Solution 2: Update your Video Card Drivers.
Solution 3: Install the latest DirectX version.
Solution 4: Disable Optimized Solution.
Hope this helps you buddy. For more reading you can refer to this link
Answered By 0 points N/A #140788
Hi Frank,
You need to install a simple update on your system to get this issue resolved. Just Install " Running Windows 8 release preview or Windows Server 2012 release candidate". This update is available from Windows Update. Just follow the steps given below to install this update on your system.
1. Open Windows Update in control panel.
2. Search for additional updates.
After you have installed it on your system, you need to reboot it. Your issue will be resolved.
