Gene C Silva 130 points N/APosted on - 02/23/2015
I have a PC with 8GB RAM, MSI G series Mobo, GTX 760 and AMD FX-8320 with 4.0 Ghz speed. I think this specs are good for playing games but now my pc is performing very low on almost every game. At present, I am trying to play Guild Wars but nothing seems to work. I can only get <5 fps which is not good at all. Help me.
Even if you have high qualified hardware, your PC might be slow because of its software configuration. If your OS and system is clean, only then you’ll have its best performance.
First of all, make sure that your system is free of junk files. CCleaner, Wise Care 365 etc. are some of the best software to make your PC light. Scan your PC for junk files, remove them and defrag your disk.
Next, it’s time to keep your driver up-to-date. Get the latest drivers for your hardware. Download GTX 760 driver.
If still no solution, you should try re-installing your Windows. Make sure to install 64-bit OS otherwise, you won’t be able to utilize more than 4GB RAM in 32-bit Windows. Learn how to install Windows.
I think you are not checking the system requirements of the games you are playing before you even install them. Installing a game and hoping it will work on your computer is not the right way to do it. Checking the system requirements is always the first thing you should do to avoid wasting any bandwidth downloading the game.
Guild Wars 2
If you have the classic Guild Wars, it supports Windows XP, Windows Vista, and Windows 7. It requires 1 GHz Intel Pentium 3 or faster processor, 512 MB RAM, video card with 64 MB video RAM (NVIDIA GeForce 4 Ti series, ATI Radeon 9000, or better), 5 GB free space, sound card, and broadband internet connection.
If you have Guild Wars 2, it supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 2.4 GHz Intel Core 2 Duo or faster processor, 4 GB RAM, Microsoft DirectX 9-compatible video card with 256 MB video RAM and Shader Model 3.0 support (NVIDIA GeForce 8600GT, ATI X1900, Intel HD 3000, or better), 50 GB free space, sound card, and broadband internet connection.
1....
