anonymous
7060 points
Posted on - 04/09/2012
I’ve been teaching online and this is the seventh time that my computer hangs up while using powergramo. I’ve purchased powergramo professional. Is it necessary for me to use the old version? I’m worried about delaying my classes because my students get pissed off.
How can I fix this? I need your help!
My pc hangs up everytime I use powergramo. Please help.
PowerGramo are usually using for Skype call. This software can deliver or handling excellent voice and video transfer. It can give crystal clear digital HD sound and video. When you will try to use that, your PC anti virus can detect it as a malware or virus. But that is not virus, you can use it by turn off your anti virus program and then enjoy with PowerGramo. That’s a easy program for novice user.
You have PowerGramo license version, so there have no limitation to use that software in your PC. Just make trusted this software for your anti virus and then run it.
Thanks
PowerGramo Professional is a tool used to record any kind of Skype calls. If your computer frequently hangs every time you use it, make sure your computer meets the requirements. PowerGramo Professional supports Windows 2000, Windows XP, Windows Vista, and Windows 7 and requires only 128 MB RAM. Since it is only a recorder, it doesn’t require any specific video card support.
This means it will work regardless of whatever video card you are using. If you are using a higher version, check your version’s system specifications because there are times the specifications of the new version differ from the old version. It may also help if you add more RAM.
