PC suddenly hangs and stop working
It is a common problem in PC. It happens from many years. Many software creates this kind of problem. Many softwares cannot match with the PC. So, sometimes It creates many problem thus your windows hangs. Or, sometimes it because of your slow RAM. Low RAM computers often hangs. Or, sometimes it because of the virus of your computer. Computer often hangs when you play the games which data are not well organized. sometimes when you play games your PC hangs. So, use those softwares which matches with your PC. If you do not have enough RAM I am suggesting you to increase your PC RAM.And don't play the games which data is error or corrupted.
If your computer unexpectedly freezes while you’re working, press and hold on the power button on the CPU to force it to shut down. When the CPU turns off, wait about 10 to 20 seconds before turning it on again. Then before the Windows logo appears, press F8 to access the Windows Advanced Boot Options.
In the Advanced Boot Options screen, select “Last known good configuration” then hit Enter to boot. Restart whatever it is you are doing and check if it fixes the problem. When you need to open multiple applications when working and your system gets slower and slower, try increasing your computer’s virtual memory.
When your computer starts to slow down, it is a sign that the page file usage is past 50% or the virtual memory is at 50%+ of its usage level. Because I use a system monitor on my computer, I always notice this issue when the page file usage is climbing more than 50% and it’s really getting problematic when the usage reaches 75%.
This problem happens when your computer has low physical RAM and the computer is forced to transfer data to the page file to balance the load. This only happens when you open multiple programs at the same time but if you open only one or two, I don’t think you will have a problem. One solution is to add more RAM.
