sarwar
Posted on - 12/03/2012
It is troubling my PC.
Suddenly my PC restarted automatically and showed a blue screen error message that, “Physical memory dump Etc.
I am tried some more times to start my PC, but result is same.
Why it’s happening again and again?
My PC restarted and showed a blue screen error
Big problem. This can happen due to your motherboard or HDD problem. I can’t suggest anything about motherboard but can say something about HDD.
May be your HDD is troubling with bad sector. You can’t recover it, but it is possible to fix the problem.
1. Remove your HDD from your PC and connect to another PC as a storage device.
2. Now check it with any HDD software ( as like Magic Partition)
3. If it finds any bad sector shrink it from your system drive and hide this new partition with HDD software.
4. Now setup new windows.
microtek
A.O.A
Dear Sawar
First of all you open your computer and blower the system, if you do not have blower then clean your PC fans with brush, sometime this problem is coming if your system's fan has many dust.
The second cause of blue screen come if your system's ram also pack with dust please off your system and pull the ram module and put again after clean. After that run your system I hope your system is again good working, if not then may be some problem with your windows system files may damage. Try to install windows 7 again.
This problem also may with hardidsk like as bad sectors.
Try and enjoy your life,
Best of luck
This blue screen signal is not a good thing at all. When it happens, pc becomes stopped just at that moment. It means your system is crashing.
This problem can be occurred for many reasons. Some common reasons for this trouble are over locking, dust, overheating, power supplying problem etc. But the most common reason is error in a registry file.
To solve this problem,
1. Be sure that power supply is in good health.
2. Be sure that your pc doesn't become overheated.
3. Clean dusts.
To fix the registry,
1. Right click on my computer.
2. Select Properties>>Advanced tab
3. Under Performance tab, click change.
4. Go to advanced tab > change
5. Select custom size button>>initial size button.
6. Make the size 0.
7. Select maximum size and turn it into 0.
8. Click set, restart your pc and defrag disks.
9. Once again, go to the custom size.
10. Make the Initial and Maximum page file size 1.5 times the amount of ram your computer has.
11. Click the set button again and restart your pc once again.
12. Done
Hope no more blue screen error will occur.
Hi
If you're getting a blue screen and then your computer immediately reboots without being capable to examine the text in the blue screen, pursue the steps below.
Firstly on the desktop right-click MY COMPUTER
Click properties, then advanced tab
In advanced tab click settings button under START UP AND RECOVERY. In the START UP AND RECOVERY window unchecked the automatically restart check box.
Click OK.
Thanks
Hi
If you're getting a blue screen and then your computer immediately reboots without being capable to examine the text in the blue screen, pursue the steps under.
In advanced tab click settings button under START UP AND RECOVERY. In the START UP AND RECOVERY Window unchecked the automatically restart check box.
Click OK.
Thanks
Hi Sarwar,
Thanks that you have asked one more.
Dear this error has two major causes.
The physical memory dump error takes place when RAM is out of order or when hard disk having some problems with it.
The blue screen error called Fatal Error.
You have to take these steps,
Open the case of your computer and Clean it via Blower. Remove all Rams And Hard Disk to clean.
After dusting, Run system again after attaching all hardware back to the system. Mostly such problems recover by only dusting.
If you see it again check your RAM, is it ok? Not heating up more or any damage if?
Then check your hard disk, windows is in perfect state? Any corruption in windows files?
If yes Reinstall windows.
Your problem will solve.
Thanks
Hi Sanwar
Don't worry it's a common problem. You can apply many techniques to fix this issue. Go this Techyv page too to get more techniques to fix this issue.
Trouble to shut down my computer
