I have a windows PC, and at times my screen freezes, and then a blue screen comes up saying that my pc has encountered a problem and after restarting everything works just fine. This has been going on a lot lately and I am concerned because my pc has a lot of important work. How can I solve it?
My PC Screen Freezes Issues
The error message you are getting is what is known as Blue Screen of Death. It is an error that indicates that your pc might have some corrupted software, missing DLL files or some hardware problem or some problems with your driver.
So all you have to do, if a code is coming up along with the screen, immediately note it down and search about it because this is a distinct code that will help you in finding what problem it is your pc has encountered, and you can find solutions for it. Sometimes you may even get a QR code alone displayed with the message. You can scan the QR code, and it takes you to a webpage that describes what the problem is and possible solutions.
