My PC is very slow plz help…
Remove your Processor then clean your processor slot by using newly bought paint brush and also put thermal paste in the processor so that it will help the processor preventing from overheating sometimes it is the cause of slowing the computer.
Remove your PCI land card if it OS installed it your motherboard brush the PCI slot using paint brush to brush away the dust inside the PCI slot. Also remove your video card installed to your motherboard and then brush it again the agp or PCIE slot using the same paint brush to brush away the dust inside the AGP or PCIE slot. Now, check all the cables like sata power, cable, IDE cable if your CPU have it because that is one of the cause of your computer slowly.
And the most important thing of all that check the power supply of your computer, if you need to open it then you have to see if all the capacitor is sober but if you see one of the capacitor is already blowing you need to buy brand new power supply to give the needed power of your computer.
Hi
There are lots of reasons that can cause the problem that you are facing now.
First you have to identify the problem well, Is it a hardware problem or the software problem.
Best thing you can do is check what are the programs running in the machine and how much recourses those software’s are using.
From that you can identify is your machine in under the virus attack. It is good if you can scan whole hard disk with good antivirus software and reduces the data in hard drivers as much as possible.
Remove the software’s that you have installed earlier that do not suitable to the machine performances.
I hope these will help you
Thanks
Has this been happening since you reformatted the computer or has this problem only started lately?
There are various reasons why a computer would slow down. You may have a lot of programs running simultaneously which demand a lot from your system's resources consequently resulting to a slower computer. You may have very little memory, barely enough to keep the operating system running.
Opening any other program will make the system crawl. Install additional memory to your system. A dusty computer can also make the computer slow. When there's too much heat on the system and the system's cooling components can't efficiently remove the heat from the components, the system will slow down due to the heat. So clean your system. Viruses can also slow the system down. Have your computer scanned for infections.
