My pen drive affected by unknown virus.
Asked By 7060 points N/A Posted on -
Hai
My pen drive affected by unknown virus…all the folder and files name's have change to the unread name.. ex:s«╩▐E∩.ï╞╠
Please help me because all the files is very important document.
Can u just email me the solution.
Thanks
Best Answer by Jamalia Cur
Answered By 5 points N/A #83482
Your Pen drive is affected by unknown virus.
Your important data is in your pen drive.
You want to get your data. Here are some tips for you
  • If you are using an antivirus in your computer, then update your antivirus & then scan your pen drive.
  • Use Microsoft security essential or ESET Nod32 for scan. They will help to protect your data.
  • If your antivirus can not delete virus, you have to install ACDSee in your computer. If you don’t have it, then download from internet and then install it.
  • After installing ACDSee, open your pen drive with ACDSee. First open the software and browse your Pendrive. It will show your files. View or copy the files.
I hope your problems will be solved.
Answered By 0 points N/A #83483
I've also posted the solution here for the sake of other people with the same problem. I hope you won't mind. Here are the steps:
1. For precaution disable Autorun in your pen drive.
a. Go to start, and open Run.
b. In the Run dialog box type Gpedit.msc and press enter.
c. If prompted for administrator password, type the password and click Allow.
d. Under the Computer Configuration expand Administrative Templates.
e. For Windows XP users, click system. In the settings pane right click Turn-Off display. Click Enabled and Select All drives in the Turn-Off display box. Restart your computer
For Windows Vista users: Expand windows components the proceed to Autoplay Policies. In the Details pane, choose Default Behavior for AutoRun. Click Enabled and click Do not execute any Autorun commands to disable.
For Windows 7 users simply download and run this file here
2. Scan your pen drive using your Anti Virus Software.
1. Insert your pen drive.
2. Go to My Computer, look for your pen drive then right click.
3. Depending on your antivirus software, click scan for viruses.
4. Wait for the scan to finish. A results box will appear.
5. Select the files to be deleted/ quarantined.
6. Click Delete/Quarantine
7. Close the program and check your pen drive for possible remnants of virus.
Answered By 0 points N/A #83484
You are facing problems because  a virus/worm that infected you. This worm will duplicate all your folders and create an executable files with its name keeping the original folders hidden.
At first, connect your pen/flash drive to a machine which is protected with an updated version of a good antivirus and fix all the virus threats by scanning it.
After removing all the infected files from the pen drive, go to the CMD on your computer and run the following DOS command.
ATTRIB -H -R -S /S /D E:*.*
Here we assume that the Flash drive is E: drive.
If you don't know how to go to the CMD then follow:
First of all open the file manager. Then go to top menu, Tools > Folder Options and select view tab.Now
mark the “Show hidden files and folders.”Go to Start > Run, type CMD at the OPEN: box, and press OK.
This will show the DOS command prompt.
