My Photo effect software is in thai?
Good Morning, I bought a photo effect thai software , When I install it, everything is in thailand, there is no function what so ever to change it to english. Can you Guys help me is there any way to change the interface from thai language to english for easy view & understanding?
Answered By 0 points N/A #198892
Hello Nelson,
If there is no option to change the language of the software from inside the program then you might want to uninstall it and install it again to see if there is an option to select English from the setup engine when you are installing the software. If this doesn't do the trick, then you will need to search on Google to find the language files you need. Here is what you can type to find what you need: "<Software Name> in English" or "<Software Name> English Language files".
P Vhilary
