My Photoshop CS6 does not work properly
Hello guys,
My Photoshop CS 6 does not work properly. All the commands are not correct like when I copy and paste layer from another file (doc) recorded as actions, preference has turn to interface and open document is tabs.
Adobe Photoshop CS6 Extended
The command “Paste” is not currently
available.
Continue                  Stop
Please can I get some help with this because the tabbed interface does not work for me?
The software is Adobe Photoshop version 13.0.
Thanks in advance.
Best Answer by Johnstoon Leen
Answered By 5 points N/A #145907
Hello Jamin,
It seems that the program is not correctly installed to your computer. Sometimes the a few setup files are left behind at the time of installation or gets deleted which results in the malfunctioning of the software. I recommend you to completely uninstall the program and install a fresh copy of it and see of the problem has been fixed.
Answered By 0 points N/A #197236
Hi Jamin Ywain,
Well it depends upon which Adobe Photoshop your are using.
If you are using 32bit Adobe Photoshop.
  1. Then there is a defect in Adobe Photoshop CS6 32Bit, It loses its current document object.
  2. You’ll get an error message when some requirement of a tool is not currently met is “xyz command is not available or not supported in current version of this tool”
  3. Where xyz maybe any valid type of Photoshop command.
If you are using 64bit Adobe Photoshop.
  1. There are some problems too in case of switching between documents.
  2. If you’ll use more than one document than maybe it’ll cause an error.
  3. You have to work on specific document at one time.
But 64bit far better than 32bit Adobe Photoshop.
I hope you’ll found some easy way for your regarding this issue. Good Luck!
Jhonstoon Leen
