I just created a portfolio site for my Aunt and it works perfectly fine with MAC. The problem is, when I use it with other laptop, the logo is covered by two slides and does not respond when it is set with relative. I really can’t find a solution to this problem.   Â
My portfolio site works with my MAC but not in the other
Hi Samerah,
This has been a lacking program on the other laptop that needs to be install in order to view your Aunts site. You should install Java on the other laptop and update the browser because some outdated browsers can cause this errors.  If your using old laptops then i conclude that would be the reasons why most of it's slide did not responded due to its old  hardware specification. Just buy a new one to make it work.
Thanks,
TonyÂ
This seems to be a compatibility issue between the browsers you have been testing it on. The one which runs it without any changes is fully compatible with your site and logo while the other is incompatible.
Try using same browsers on the both laptop and verify the result. Contrarily, you can install additional plug-in for logo in the browser of the other computer. Java will do this work for you, just download and install it on the PC with problems.
For java download visit https://www.java.com/en/download/
