My presentations videos are not played in other devices or PCs
My presentations videos are not played in other devices or PCs. I think its about the location of videos but I have saved those videos in the same device or location in other PCs. But still my videos are not played. I am using MS PowerPoint 2007. What could be the problem?
Answered By 0 points N/A #93094
Is it already inserted? If it is, maybe the movie file format is the problem. Try playing the movie in Windows Media Player, if it doesn’t play, windows will give you an error message and help link to help you solve the problem.
If your movie plays in the windows media player, you can insert it as a clip in your powerpoint. Do the following:
In the text group (under insert tab), click on Object. Under the “Object Type” list, click “Create from file”, then enter the name of your movie or click browse to find the location of your movie.
Also note that you can only play movie in powerpoint by clicking buttons in windows media player.
