This is my primary attempt to construct Win7PE
Hi experts,
I'm a fresher to WinBuilder as well as this is my primary attempt to construct Win7PE.
After that the construct is done as well as I attempt to run it by using the VM Player. But I received the following error message.
Win7PE SE – VMwarePlayer
You have configured virtual machine to use a 64-bit guest oprating system. However, 64-bit operation is not possible. This host VT capable but VT is disabled. This is usually because VT has been disabled in the BIOS/firmware settings or the host has not been power-cycled since changing this setting. Please:
(1) Verify that the BIOS/firmware setting enabled VT and disabled trusted execution.
(2) Power cycle the host. if either of these BlOS/firmware settings have been changed.
(3) Power cycle the host, if you have not done so since installing VMware Player.
(4) Update the hosts BIOS/firmware to the Latest version.
For more detailed information, see https://www.vmware.com/support.html
Continue without 64-bit support?
Yes No
I am using Windows 7 Enterprise (32bit) – German Interface.
I've attempted it with English Interface similar version as well as I received the similar error.
Source edition: Windows 7 Ultimate 32-bit.
