My Printer Isn’t Printing In Black Color
I am running an internet café with so many customers running in and out of my shop every day suddenly My Printer isn’t printing in Black color, and I am clueless about what happened. What Should I Do?
To Start
If your printer suddenly won’t print black like when you run out of ink, here’s how to check the ink levels of your printer. Click “Start” or press the Windows key then in the search box type without quotes “devices and printers” then select “Devices and Printers” on the list. On the next screen, click the printer you want to check.
You will see the ink levels displayed at the bottom of the “Devices and Printers” section. The details will appear in the status area which you can click for more information. For Canon printers, start Canon IJ Status Monitor then go to “Maintenance” tab which displays the “View Printer Status” screen. From the pop-up screen, you’ll be able to view the ink levels.
Click “Ink Detail” to get a more detailed look into how much ink is left in your Canon printer.
