How to permanently delete printer list on my Win Vista
Misha Bell 140 points N/APosted on - 07/16/2011
Dear Experts,
We are using an HP machine running on a Windows Vista operating system back in the office. And, I have a total of seven printers that I have access to print. The four of those are of not much use to me and is a little bit far from my location so I deleted it and retained the three. But, to my surprise, the next day, after restarting my computer, I noticed that the seven printers are still in my PC.
How do I permanently delete the four other printers? It which makes my list of printers crowded, so I hope someone can help me with the best solution.
Dear Misha Bell,
Here is the permanent solution for your issue. You just want to do simple steps:
Open your ‘control panel’ and then open ‘printers and faxes’ icon.
Select ‘Tools’ in menu and select ‘Folder Options’.
After opening ‘Tools’, press ‘View’ Tab and uncheck “Automatically search for network folders and printers” and press ‘Apply’ then press ‘OK’.
Now restart your system. Hope your issue will be resolved after this. Remember, before doing this steps, delete all four printer first which you did not want to see in your attached printer list.
Regardless of what version of Microsoft Windows you are using, here’s how to properly remove printers on your computer. First, you need to remove or uninstall the printer software you installed for the printer to remove the driver from your computer. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your printer software among the applications and click “Uninstall”.
Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then restart the computer. After booting, click “Start” then “Control Panel”.
On the next screen, set “View by” located on the upper right corner of the screen to “Small icons” to view all settings. Click “Devices and Printers” then on the next screen under “Printers and Faxes” section, see if the printer you removed still appears. If the printer is still there, right-click the printer and select “Remove device”.
Remove printer
After this, click on any printing device to display the additional menus and click “Print server properties”.
Click Print server properties
In “Print Server Properties” window, go to “Drivers” tab and select the printer you want to remove. Click “Remove”.
Remove printer driver
Click “OK” all throughout then restart the computer.
1....
