My RedGate SQL Data Generator 2 clashes every time.
Hi! I am using RedGate SQL Data Generator 2 to populate my database for testing my applications.
The problem is that every time I open an existing project, the application crashes.
This is a very good application since I work a lot with SQL databases for all my works.
How can I fix this?
I do not want to be inputting data manually even when I am just testing my application.
Thanks a bunch.
