ney steele
20 points
Posted on - 06/17/2012
I bought a new router. I want to connect a wireless network. I already added new network on my personal computer so that I could use wireless connection. But it doesn't work. What's wrong with it? Can anybody help me on how to connect a wireless network?
My router doesn’t connect wireless network. What’s wrong with it?
Hello Ney Steele,
Thank you for asking that question. Your problem is all about on how to connect your router from a wireless network. There maybe a problem with the network you want to connect. To set-up a router it must be carefuly configured when they are first installed. Your router must be set-up with an IP address and security features.
I hope this helps you solve your problem. But if still does'nt you must contact right person to set-up for you.
—Clarence
A router or Wi-Fi router is the device where you connect your Android and iOS phones to so you can connect to the internet. This is the device that allows you to connect your wireless devices to the internet. You don’t use it to connect to other wireless networks because the device itself creates a wireless network.
Before you can use a router, you need to name your network or give your wireless network a name. By default, the router uses the factory name of the device as the network name or SSID. SSID stands for “Service Set Identifier.” This is the Wi-Fi name. Open your web browser then open your router’s control panel.
You can find the instructions in the manual that comes with your device. Go to “Wireless” section then locate the SSID. Change the name indicated in the SSID field with the name you want. Next, go to “Security” section then change the password in “Pre-Shared Key.” Set “Pre-Shared Key Format” to “Passphrase” instead of “HEX (64 characters).”
When you are finished, click to save the settings.
