I am unable to play videos from any site using my Samsung Star gt-s5233; this is despite the fact that this gadget has all the features and software in place. What is the cause of this problem? Please help
My Samsung Star gt-s5233 won’t play videos
Hello Jayrose Miranda, the issue regarding how to play videos on you Samsung Star gt-s5233 is because of the type of the video file. Your gadget has features and software’s that would play this but one factor is the Adobe Flash player. When you tried to play these videos does it come up with an error to download an Adobe Flash Player? If so, you can just download this software so you can play these videos.
If you are trying to watch these videos on Youtube.com unfortunately your gadget do not support the .flv files (typical file formats in Youtube.com). Samsung Star gt-s5233 maintains the avi, wmv, mpeg-4 and 3gp. There is a certain program that you can use from your PC to convert videos to .flv files format so you can watch videos on your phone.
Are you able to access the internet generally using you phone, even before we come to playing videos from the internet with it? Playing videos on the internet using your mobile phone will require that your phone has access to the internet, and therefore you will need to check if there is a problem with the settings and rectify it. Note that if the internet connection is too slow the videos will not be streamed well for the process requires a lot of bandwidth.
The other reason as to why you are not able to play videos online is because you have not installed a flash plugin yet. Flash plugins are required to play online videos and games and therefore you will need to make sure that you have installed one on your phone.
-Chalk Talk
Okay.. I will check all my settings on my unit regarding the adobe flash player and other settings.. At least I’ve got the idea about what is needed to play games and other applications. Techyv thanks for the help.
