My sc2mapanalyzer do not work with Patch 17 editor.
Whenever I tried to do so it threw an error message. I cannot understand the message.
Please help me to solve the issue.
Sc2mapanalyzer.exe – Entry Point Not Found
The procedure entry point SFileCloseArchive@4 could not be located in the dynamic link library StormLib.lib.
Try the following steps:
1. The dll file is not being located by the application. Check the program files folder and make sure that all the files have been loaded properly during installation. If the dll file is missing then download it and copy it to the program files folder.
2. Check the bin files if they are corrupt or not. If they are corrupted then you can repair them. Go to Start button and click on the command prompt. Type scf/scannow and hit enter. Now the bin files will be repaired.
3. If the above steps did not solve your problem then do a full reinstall of the software on your computer.
