My shared Outlook 2007 Calendar doesn’t work on Curve 8330
Hello all,
I am using Windows Vista OS with a shared Outlook 2007 Calendar. I recently updated my desktop software, which is Curve 8330. During the update, the process hanged for a few seconds and then continued. By the end of it, I got an error message with the figures: ‘0x83860028’. The calendar doesn’t sync at all. The error should be due to a bad bit of data or software issue.
Please help me figure this problem out. Thank you!
